MPC 2800 DOOR SWITCH error
  • fshead
    • 2356
    i have a open right door switch i couldnt clear,as i was picking up "working machines"
    i didnt have my meter to ck front door/right door switch assembly.service mode input ck shows 1 that doesnt change wth door close/open.
    IS there only the one interlock for the side door? the machine sees the fnt door open/close..
    i know about the top duplex switch but want to make sure there isnt another "hidden" switch on the right door assembly.
    thnx
  • JustManuals
    • Jan 2006
    • 9919
    Re: MPC 2800 DOOR SWITCH error
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • lganaden
      • Jan 2013
      • 10
      try to double the check the push switch located at the exit unit assembly, this switch has been activated by closing duplex area, try to check may be the switch actuator has broken.........good luck.........
      • fshead
        • 2356
        i found the problem,after reading 400 of the 1650 pg manual,checked cn204 on IOB brd and finally
        found that the switch i thought was the door switch was only front even though the right door activates it..
        the small switch had the center actuator totally gone and just looked like a random piece of plastic.
        after taking off the side blue cover i saw a set of wires..
        felt lik a dumb azzz but 1st time in this machine...
        thnx
