I have a Gestetner 3222 copier. I finally got the paper pickup assemblies and clutch for the paper trays to work. However, the paper that comes out of the unit is dirty. I realize that the unit needs to be cleaned. What parts do I need to concentrate on? I would imagine the rollers, platen need cleaning. Also some of the loose toner needs to be removed. What is the best way to remove the toner? A shop vac or similar vacuum? I can only imagine that by wetting the toner will only smear it around and make it worse.
I also need to change the drum/photoconductor unit (PCU) on this machine. What is the best/cheapest source for these? I thought I saw one that is $79 somewhere.
Mike
Mike
