Warning remove paper, system error (0990)
  • Questfor
    [Error Code] Warning remove paper, system error (0990)
    Hello to all,
    First timer.
    Having problem with a RICOH multifunction printer GX3000SF .
    I am receiving an error code to remove paper.
    Display reads, "Warning" Remove paper, System error (0990)
    Unable to continue with any other functions of printer due to this error.
    I have checked every possible access to remove paper, checked guides,feed and all paper paths and have found nothing.
    I have searched for system error 0990 and can not find solution.
    Would appreciate your professional impute to direct me to what I need to do to solve this problem,
    Thanking you in advance for any information you might can supply.
    Sincerely,
    Questfor
  • JustManuals
    • Jan 2006
    • 9838
    Re: Warning remove paper, system error (0990)
    Paul@justmanuals.com
    • TonerMunkeh
      Professional Moron
      • 3865
      SC990 means the maintenance unit has failed and requires replacement. That's why the error won't clear. I think the part number is J007 0413.
      Hit it.
      • Questfor
        Toner Munkeh,
        Thanks for the reply, will look into replacing maintenance unit.
        Have a great day.
        Sincerely,
        Questfor
