Ricoh mp4000 transfer belt moving to rear site
  • Mark Bbb
    • Jun 2012
    • 1662
    And when the belt has moved to the rear site, it makes a noise, because the belt rubs over the belt holder bracket. Replacing belt and blade don't solve the problem. 3 units have this problem.
    Thank you for your good answer.
  • xatrix
    • 27
    Re: Ricoh mp4000 transfer belt moving to rear site
    sounds like one of the bearing are not moving freely have had this happen alot. replace the bearings on the belt assy
    • Mark Bbb
      • Jun 2012
      • 1662
      Even with a mp4001, with counter 60K, the transfer belt has moved to the rear. Could it be because of the movement of the drum, which is not fixed in its frame (it fact the drum is very movable). So i do not believe it's a bearing. There are some bulletins concerning this problem, do they help?
      • JustManuals
        • Jan 2006
        • 9865
        Paul@justmanuals.com
