How to regularly clean the Ricoh MP7500 to keep it good running?
  • vietbooster12
    Hello all,
    I just bought a USED Ricoh MP7500 and I would like to make the the copier running good. What areas of the copier should I regularly clean or replace in order for the machine to run smoothly? Thank you.
  • sandmanmac
    • 3981
    Re: How to regularly clean the Ricoh MP7500 to keep it good running?
    Originally posted by vietbooster12
    Hello all,
    It's pretty insulting that you think copier service (on a 75ppm machine at that) can be reduced to a few lines of text. Seriously!
    • totoro
      • 568
      If you want just general info then ...
      Clean ADF sensors, rollers, belt . Change as needed.
      Keep your optics clean
      Clean thermistors, change fuser rolls and web when needed
      Clean ID sensor and drum unit about every 100k
      Replace developer and filters every 300k-500k or when toner dusting machine
      Replace charge wire and grid every 300k
      Clean or replace paper tray PU, Feed and Sep rollers as needed.
      That should do you.
      Totoro
      • rsyarcia
        Hair Straightener Tech
        • 711
        follow the PM table from the service manual
        Nobody is perfect..
        • vietbooster12
          Thanks alot!
