Waliul
  • Waliul
    • Jul 2010
    • 20
    [Error Code] Waliul
    I have a problem on Nashuatec SP3400SF multifunctional copier error code SC542. Is there any one inform me
    how to reset this error code.
  • sandmanmac
    • 3981
    Re: Waliul
    Probably THE most common SC on any Ricoh (Nashuatec)!
    Fuser error. Google it, and/or call a tech.
    • pro.b.unal
      • Dec 2008
      • 42
      Re: Waliul
      press stop key, press 1 , 0 , 7 and than press hold down start key. You see maintinance mode on the display. you must select press down key fusing eror code clear, press OK key, turn off machine and turn on
      • JustManuals
        • Jan 2006
        • 9838
        Re: Waliul
        Paul@justmanuals.com
        • Iowatech
          Not a service manager
          • 3930
          Re: Waliul
          Hopefully the error code was caused by a power surge and this procedure works, but if the thermistors are worn out and things start melting after you do this, you're on your own.
