Cause: the toner concentration of developer is too high.
Solution:
Change pcu , or developer, or use genuine ricoh toner ;-)
Ricoh 1022
Re: Ricoh 1022
if your PCU is new check the quality of the toner if you have another type change it.Leave a comment:
Re: Ricoh 1022
Maybe also turn on transfer roller cleaning? That's in SP2 service mode, near the end.Leave a comment:
Re: Ricoh 1022
Both, PCU is overtoned and the transfer roller is dirty from the excessLeave a comment:
Ricoh 1022
What causes a black streak on backside of copy @ lead edge; from side to side. If multiple copies are made only shows on the first copy; yet on every single copy. Transfer roller or PCU unit???
Thanks!!!Tags: None
