Newbie Please help - Ricoh Aficio 1018
  • 999marko
    Hi,
    First my aplolgies for my lack of knowledge!
    I have just purchased a second hand Ricoh Aficio 1018 a few weeks ago.
    All has been working well and I am very pleased, however there are now black lines appearing on everything when I print or copy - Do I need to clean/change something? If so what... The manual I received is very basic but doesn't talk you through any issues like this...
    Any help/advice would be gratefully appreciated!
    Many thanks in advance!
    Mark
  • joher
    • 43
    open the drum unit and clean the recycal unit problum will be solved,,,,, other wise repaleced the cleening balade or charge roller,,,,,,,
    • 999marko
      Hi Joher,
      Thanks for your quick response!!!
      Could you talk me through how to open the drum unit and clean the recycle unit please!!!
      Many thanks,
      Mark
      • DocF
        Old Retired IKON Drudge
        • 41
        Messing around inside the drum/cleaning unit on these machines is a recipe for disaster. You will undoubtedly make things worse. This is a job for a trained technician. There is a very good Ricoh dealer in your area; I would strongly advise calling for help.
        The Aficio 1018 is a good machine which has few of the issues of the earlier versions. I would spend the money to have it properly serviced.
        Doc
        • 999marko
          Hi Doc F
          Thanks for your words of caution!
          I will call a repair guy and get a professional to take a look!
          Thanks a million!
          Mark
          • Jomama46
            • 2900
            Nicely handled Doc
            sigpic
            A+; Network +; PDI+
