RICOH MP C6000/7000/7500
  • MrNhan
    • Jun 2025
    [Error Code] RICOH MP C6000/7000/7500
    ricoh aficio Mp c6500 color SC 400 - SC 438 Hepl
  • sandmanmac
    • 3979
    Re: RICOH MP C6000/7000/7500
    First of all, tell us ​what you're done to help yourself? Apparently, absolutely nothing.
    • MrNhan
      Hello!
      I have a sc438 error report LANIER LD 260C. I cleaned the sensor under conveyor Bell, but does not solve the problem. people help . Thank you all
      Sorry I'm a little less English. I'm in Vietnam
      • Eric1968
        • 2458
        SC400 has something to do with the ID-sensors (loose harness, defective/dirty ID-sensors). Take the ITB apart check all parts and clean everything and also check the ITB Drawer connections.
          • 37345
          Hello!
          First, the LD 260C does not have a "conveter Bell". It does have an ITB. If you do not have a service manual for this machine, you most likely did not clean the ID sensors. The manual gives very specific step by step instructions for cleaning/replacing the ID sensors. If cleaning does not correct the error, then the ID sensors will need to be replaced.
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
            Paul@justmanuals.com
