Ricoh 3228c By pass paper misfeed problem
  • jethro tull
    • Jul 2008
    • 54
    Hi,
    When i try to print through by pass tray(even if it is a3,a4 paper plain or thick) when it runs in the midlle it stops.
    The copier pulls in the half of the paper and then it stops.
    What can i do?
    Thanks in advance.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh 3228c By pass paper misfeed problem
    Does the copier give an error message? Have you checked the logging data to see what the latest jam location is?
    • Eric1968
      • 2458
      Registration clutch?
      • jethro tull
        • Jul 2008
        • 54
        How can i check it?
        Can you give me instructions?
        • jethro tull
          • Jul 2008
          • 54
          How it looks like and where is this clutch?
          • Eric1968
            • 2458
            If you don't know how to find the registration clutch, there's only one option : "Call a tech!"
              • 37489
              Originally posted by jethro tull
              How can i check it?
              Obviously not trained and does not have a SM.
              • jethro tull
                • Jul 2008
                • 54
                Thanks man.
                I've changed the registration clutch and by pass rollers and now is working.
                • jethro tull
                  • Jul 2008
                  • 54
                  Yes not trained.At least i try to fix something (if it's not to difficult) by myself before i call a tech.
                  Thanks anyway.
