RICOH MPC 2500 with unknown the cause
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    First machine display "please wait"
    then we replace the HDD disk with new and formatted it and machine warming up and print well
    second we make print of test pattern it was well but when we make a copy of it the copy was shown as in following attachment we replaced the CDD but without any Interest.
    • 37489
    Re: RICOH MPC 2500 with unknown the cause
    Did you scan the attachments on the machine you are having trouble with or on a machine at your office. If it was not on the machine you are having trouble with, I would say the IPU board.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Do a memory clear on printer (just in case) and copier applications, then re-seat the memory DIMMs.
        • Mar 2012
        • 171
        NO, I scan with machine at my office not the machine which has the trouble.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          That's pretty F'ed up!!! I'm with slimslob on the IPU.................
          Mystic Crystal Revelations
            • 37489
            Two places the image can get corrupted. The HDD, you already replaced. The IPU board.
            • Tonerbomb
              • Feb 2005
              • 2589
              Does this mean you replaced the CCD??? And if you did, was the SP data for the new CCD entered into the machine??? Each CCD is factory calibrated and has it's own data to enter into the machine.....
                • 37489
                I did some checking. This machine does not have an IPU. Image processing is done on BICU board.
                • JustManuals
                  • Jan 2006
                  • 9838
                  Paul@justmanuals.com
                    • Mar 2012
                    • 171
                    Thank you very much Mr.ruben
                    the problem has solved as your suggestion
