Ricoh C830DN Default to Simple Screen
  • staze
    • Oct 2012
    • 8
    All,
    Hopefully this can be done. We just installed a C830DN for our student body to use, and I'd like to keep them out of the more complex settings, and just show the simple screen.
    Is it possible to either A. Default to the simple screen on boot, or better B. lockout all but the simple screen completely?
    Thanks!
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh C830DN Default to Simple Screen
    Complex settings? C830 is a printer...
    • staze
      • Oct 2012
      • 8
      Indeed... but these are college students. If things don't print the way they want, or if they're bored, they're going to start poking around menus, which I'd like to avoid.
        • 37514
        Have you considered putting a lockable cover over the buttons?
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          On the copier version you can lock out the system settings with a machine administrator lock, lock out the use of any screens with a number or user/pass combo, and then lock out the creation of these access codes. All these settings are in System Settings -> Administrator Tools, they may be the same on the printer version.
          • staze
            • Oct 2012
            • 8
            Have you considered answering the original question rather than proposing an alternate solution first? =/ I can't say I've seen a "lockable cover" option for this printer...
            • staze
              • Oct 2012
              • 8
              okay, I'll see what I can find. I really like Ricoh printers, but they seriously have engineers doing their firmware design, because some of this stuff just seems mind-numbingly obvious.
              • teebee1234
                • Jul 2008
                • 1670
                You need to enable 'Menu Protect" Level 1 or 2 in User Tools (after you enable Administrator Management). This will prevent prying eyes and fingers from sabotaging your settings. The specifics of what Level 1 and 2 cover are listed in the User Guide on pg. 213.
