possible electrical problem Aficio 2045
  • jtd55
    replied
    Re: possible electrical problem Aficio 2045 (SOLVED)
    Hi fellow tech guys
    Problem solved with replacing fuser unit
    Thanks again for replies to the problem
    jtd55
  • Codex
    replied
    I had the same problem, replaced the entrire fusing unit (changing only thermistors and thermostat didn't work), and the machine works fine without any problem
  • ccchuah
    replied
    Replace the either one or both of the thermostat housing (G065-4105) will solve the problem.
  • jtd55
    replied
    Thanks guys for all your replies calling in today will let you know how i get on
    Kind regards
    jtd55
  • sandmanmac
    replied
    Originally posted by Users Tech
    try taking out the fusing unit and turn on the machine and see if it still trips off the power. it will display an sc but you can clear the sc by 7807 after you put back the fusing unit.
    All that can be accomplished by simply leaving the front cover opened, as Eric stated in the first reply.
    ALSO, SP7807 resets the SC/Jam counter only.
    Although, in a way you're right, because by simply entering SP mode on this model and rebooting machine, the SC reset is done anyway. However, the SC log is something we often want to maintain
  • Users Tech
    replied
    replied
    Perhaps someone has an electric heater setting under his or her desk on the same circuit breaker. 1200 watt heater and a 12 amp copy machine add up to more than the 20 amps that most office circuits are. HAVE THEM PROVIDE A DEDICATE 20 AMP CIIRCUIT JUST FOR THE COPIER. This will power the copier plus your vaccuum and you laptop.
  • imaginemoko
    replied
    looks like electrical overload on the customer. perhaps the machine is plug in on a extention cable hosting multiple appliance... anyhow good luck Sir.
  • Eric1968
    replied
    You can start with switching the machine on with the front door open, to prevent the fusing unit from warming up, and work from there. You can also try another outlet, in some room at the other end of the building. Maybe there's something wrong with the electrical system at the customers' site.
  • jtd55
    started a topic [Electrical] possible electrical problem Aficio 2045
    Got a call to go to a Aficio 2045 customer saying when machine switched on it trips the power off
    to rest of office im thinking poss power supply unit, fuser any you guys had this prob before or got any other
    ideas were to look
    Kind Regards
    jtd55
