Ricoh 3053 Service Code for Toner Display
  • Johal
    I was wondering if you could help. When I getinto the Service mode on the older machines I am able to display the toner iconby entering these codes 5061001# but this code is not valid for the 3053models. I have come across something else by going through the search panelsomething that is close but may not be the correct one 8781001#. However I cannotactivate this and change the result from 0 to 1. Are you able to assist in mefinding this icon.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Ricoh 3053 Service Code for Toner Display
    Paul@justmanuals.com
    • Counsel
      • Aug 2011
      • 529
      If you mean the little bar graph looking icon i am not sure you have that on this black and white machine. I think they have to go to the check status menu under maintenance and check toner status. I am not for sure but I don't see an SP in the manual for displaying the toner icon.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        What is a 3053? Did you mean 3035? If the SP is not present in the list then this machine does not support it. Please read the service manual before you go changing any SP settings.
          • 37489
          3053 is one of the new models. Replaced the 2852. It is a B/W model.
          • semi
            • Sep 2008
            • 193
            If a were you I'd look under special service mode
            • Polarbear
              • Feb 2012
              • 1070
              Look for wording like "toner remaining icon display". On the b/w machines it looks like a horizontal toner bottle that is coloured in black when full. I know the sp ends in 618 if memory serves.
              Sent from my GT-P7500 using Tapatalk
              Press the GREEN button!!
                • 37489
                The proper SP is 5061. Other than color machines, I can only find it in the service manual for the D059 series production B/W.
                • Polarbear
                  • Feb 2012
                  • 1070
                  Slimslob you were right! My bad - wasn't near the office when I typed the reply last night!
