MP 6001 hard drive
  • fshead
    • 2376
    MP 6001 hard drive
    hi.
    i just picked up a lease return savin 9060 wth 60k
    that was coding out sc860,870.
    after powering it up i tried to format hard drive but failed and
    i decided to pull the hard drive but found out someone had taken it out..GONE!!!
    not sure if was a tech or customer worried about security on drive.
    i assume the drive is a SATA hd.
    can i just use a laptop sata drive? 120gig?
    what size and any steps i might not have thought out?
    thnx
    • 37489
    Re: MP 6001 hard drive
    Thinking about most of the SATA drives that I have seen in Ricohs, they are laptop drives. Usually at least 80G.
    • Lagonda
      • Aug 2008
      • 1649
      Any old full size SATA will do the job. try to get the smallest memory size you can find, it should be around 160G if my memory serves me correctly. Remember to format it on your PC first.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        any sata drive should work. The machine should auto format a new drive when it powers up, or you can use sp5832-1. Ricoh claims useing bigger than stock drives puts excessive loads on the electronics over time and can cause board failures....Never had it happen......................
        Mystic Crystal Revelations
        • Lagonda
          • Aug 2008
          • 1649
          Originally posted by Tonerbomb
          ........... Ricoh claims useing bigger than stock drives puts excessive loads on the electronics over time and can cause board failures....Never had it happen......................
          Ricoh also recommend that you buy their genuine one at 5 times the price that we buy identical HHDs from the local computer shop. Rip off merchants.
          • fshead
            • 2376
            thats why im asking..i can buy a 160g sata 2.r in laptop drive for 39 bucks off newegg..
            does anyone know if the mp 6000 copier b4 the mp 6001 uses a sata too?
            i have one hidden behind a bunch of machines and could pull that one if i need it right away..
            also do you format TAT32 OR NTFS?
            THNX
            • Tonerbomb
              • Feb 2005
              • 2589
              THNX
              Buy the aftermarket drive and save some bucks. The only problem I see that you may have is: Did they leave the mounting bracket for the drive?? Just install the new drive and let the machine format it, or run sp 5832 if it codes. The machine WILL NOT recognize Fat32 or NTFS partions. As for the
              6000 I'd have to look at one or go to the parts manual. someone here will know off the top of their head.
              • sandmanmac
                • 3981
                No. MP6000 is PATA
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Originally posted by sandmanmac
                  No. MP6000 is PATA
                  x2!
                  • fshead
                    • 2376
                    thnx all for your reply,
                    i will order a sata laptop hd. from
                    tigerdirect or other
                    • Vollegaaz
                      • 73
                      160GB SATA 3,5 inch will do, a assume that a laptop HDD is more expensive.
                      • fshead
                        • 2376
                        bought a 3.5 inch sata western digital 250 GIG as the seagate drives had bad reviews..
                        thnx
                        • Richariri
                          • Dec 2013
                          • 163
                          hi.
                          thnx
                          I replaced this hard drive last month so it's fresh on my mind. We had a doc feeder memory storage issue and decided to replace the HDD.
                          our model had one 160GB Sata HDD installed, we fitted a Western Digital 250GB Sata HDD with a 160GB partition, worked fine with a straight swap!!!!
                          I don't know if whoever removed your HDD left the mounting bracket but you'll need that.
                          hope I helped
                          Peace
                          Edit: didn't see your issue has solved. but good idea not to go for seagate, I've had a world of problems with them.
                          • fshead
                            • 2376
                            i have yet to unwrap the machine as it sat on my pickup outside and was a toasty 10 degrees overnight.
                            dropped the machine off today and will get it done next week pending "another snow storm"...
                            could never leave in ALASKA..........im not planning on partitioning drive as i think 250gig is not that much bigger than the STOCK OEM 160 gig..
                            THNX
