question on swapping out a mpc2800 drum
  • fshead
    • 2376
    i am prepping a used mpc2800 to install at an account and dont like one of the color drums.has 50k but
    there are some slight grooves in drum that i worry about..probably from a dirty charge roller..
    if i pop in a drum from my parts machine wth 2k on it should i set it as new?or just pop it in and leave it?
    i plan on swapping the full drum/dev unit as one unit..
    thnx
  • Eric1968
    • 2458
    Re: question on swapping out a mpc2800 drum
    Just swap the drum and do the normal process control procedure.
    • fshead
      • 2376
      thnx are you talking about the drum setting or developer setting..
      do you guys do a ACC calibration after swapping drums and/or developer units?
      thnx
      • Eric1968
        • 2458
        The normal process control procedure is :
        ACC Recall SP5-610-4
        ACC Recall SP1-101-1 in Printer SP
        Process Control SP3-011-1
        Process Control Result SP3-012 -> 11111111
        Line Adjustment C SP2-111-3
        Line Adjustmnet A SP2-111-1 Execute twice
        Printer Test Page SP1-103-2 in Printer SP
        • fshead
          • 2376
          ok got it..
          will copy n paste in my flash drive wth notes,info and manuals
