Ricoh mpc 6000
  • khattab.al.masry
    • 212
    [CQ] Ricoh mpc 6000
    As you see I am beginner so my question is ?
    Who to make solid test pattern with Ricoh mpc 6000.
    With my greetings.
  • etep571190
    • Oct 2009
    • 21
    Re: Ricoh mpc 6000
    Sp 2109. Chose pattern full coverage. Chose color.
    • khaled_abosere3@yahoo.com
      Head technical support
      • Mar 2012
      • 171
      Re: Ricoh mpc 6000
      To have test pattern solid as follow:
      1-enter Sp mode
      2-enter Sp 2-108 then set color what you want to "0" which means color to print and the others to "1" which means color to do not print
      3-enter Sp 2-109-2 then choose "12" 100% coverage then press OK
      4-then Sp 2-109-4 and set the color you chosen to "15" and the others to "0"
      5- the out to copy mode and choose from LCD "full color mode"
      6- press start twice and the color you want will get out
