How to enter service mode on Ricoh SP-C231 N
  • ABS tect
    • Sep 2013
    • 511
    [Error Code] How to enter service mode on Ricoh SP-C231 N
    I had a error code for a bad fuser, and once I replaced the fuser I could not do a SC reset like I am used to doing. There is no display that allows you to enter numbers. I didn't know if you hold two buttons at once, hit a certain button several times in a row while turning it on, etc. I just need to be able to get into service mode on the printer. Any help or advice is much appreciated! Thanks!
  • rthonpm
    • Aug 2007
    • 2854
    Re: How to enter service mode on Ricoh SP-C231 N
    You can use the Smart Organizing Monitor software to reset fuser codes. To do it from the machine, hold the up and down buttons for about fifteen seconds, and then press Enter. That will get you into service mode.
    • ABS tect
      • Sep 2013
      • 511
      Thank you, I just tried holding the up and down arrows for a while and then pressed the enter button and had no success. Do you press the enter button while still holding the arrows? Do you hold the enter button?
        • 37490
        This method only works on printer models that have a display. On this model you have to use the Smart Organizing Monitor software. It should have come on the CD with the print drivers. If not you can download it from Ricoh.
