I see were people said they use a Ricoh sp c820dn fuser to work on a Ricoh mp c5000. Has anybody done this and could be a little more explaining on how to do this. I appreciate any help in this matter.
Ricoh sp c820dn fuser convert to a mp c5000 fuser
Re: Ricoh sp c820dn fuser convert to a mp c5000 fuser
I've done it once - you remove the plastic piece that covers the wiring harness going to the main connector on the fuser, and then there's a couple of wires you have to swap. Off the top of my head I can't remember which one, but if you remove your old MPC5000 fuser, expose the connector wires, and compare them to that of your new fuser, you should be able to pretty quickly spot the difference.Comment
