Ricoh Aficio MPC2500 copy with using adf red backgound
  • randy tan
    • Mar 2014
    • 8
    Hi
    I am facing a problem of Ricoh Aficio MPC2500 Colour Machine copy using adf with red background but print ok. Need help to advise how to slove this problem.
  • sandmanmac
    • 3981
    Re: Ricoh Aficio MPC2500 copy with using adf red backgound
    Originally posted by randy tan
    Hi
    Memory clear has likely been done to try and resolve a problem. (SP5-801)
    Was it you?
    That's a BIG no-no!!!
    Hopefully , you have the factory default data sheet, because it will all have to be re-entered. (It's usually behind the jam removal sheet inside the front cover).
    There are DOZENS of threads on this topic. Search the forum
    • turbojetboy
      • Aug 2009
      • 279
      As above. I bet you have a few other problems, like background when copying from the glass, colour misregistration, tray regos and alignments all out, etc. It's my opinion they are never the same after a memory reset. Good luck.
        • 37490
        What exactly have you actually done so far to resolve this issue?
        • randy tan
          • Mar 2014
          • 8
          Hi
          I just found one of page for default data sheet only. I have try to auto calibration but also same. where can i find out the machine's birthmark or birthday certificate?
          • randy tan
            • Mar 2014
            • 8
            Is it without default data sheet can do memory clear?
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              There is only one, re-enter those values.
              Re-read the above post:
              • teebee1234
                • Jul 2008
                • 1670
                Was it you?
                X2, the problem will be the gray balance setting is at factory default. You will find it on the birth certificate, otherwise use the values given in the resolution below >>>>>
                [Symptom]
                Background when ADS Mode is turned Off
                In Full Color the background is a process black, In Black and White mode the background is gray. With ADS on there is no evident backgrounding. When ADS is turned off and exposure is at the center setting, backgrounding is exhibited. Print Jobs and internal prints do not have background
                [Cause]
                The gray balance adjustment NV RAM Data has been corrupted and has reverted to the default value
                [Resolution]
                Reset the value of SP 4685 - 001 and 002, SP4686 - 001 and 002 and SP4687 - 001 and 002 to the value on the Factory Data Sheet.(Located under Jam Instruction Sheet on the Front Cover)
                If the Factory Data Sheet is not available try starting with these settings and fine tuning as needed.
                • SP4685-001 to -26 SP4685-002 to -26
                • SP4686-001 to -6 SP4686-002 to -6
                • SP4687-001 to -16 SP4687-002 to -16
                • L-IQ-uid toner
                  • Mar 2014
                  • 17
                  Re: Ricoh Aficio MPC2500 copy with using ADF red backgound.
                  Are you trying to say that there is no background when you copy off the glass?
                  Maybe you trying to copy money or something similar.
                  • randy tan
                    • Mar 2014
                    • 8
                    [Symptom]
                    [Cause]
                    [Resolution]
                    Thanks will try do this step.
                    • randy tan
                      • Mar 2014
                      • 8
                      copy using glass ok, just using adf got problem with red backgroud. print counter also ok. attach with sample print.
                      • Iowatech
                        Not a service manager
                        • 3930
                        Thanks for the pictures! We're kind of visual here, and as most of us can't physically see the machine and what it is doing pictures are helpful.
                        That being said, the left hand picture makes it look almost like the machine is copying on heavier paper than it is set up for, or maybe there is a problem with ITB or fuser cleaning (the repeating image is the clue for that). Maybe take a look at those to make sure they aren't the problem.
                        • sandmanmac
                          • 3981
                          I'm intrigued by how a nearly 8 year old machine only has 2000 total pages on it.
                          Me thinks there are several circumstances that we haven't been informed about that lead to this condition.
                          Not to mention, without a copy of the original, who knows what that copy should actually look like? (aside form the obvious issues)
                          • mohan
                            • Oct 2013
                            • 86
                            Hi
                            If the problem occurs only when using the ADF, I would make sure the anti-static strip or mylar on the underside of the adf is not overhanging the slit glass. Stray fibres from these can refract light and project it onto the originals, creating weird coloured lines on prints. Try budging the adf as far to the left as possible and see if it makes a difference.
                            • kannuki2
                              • Feb 2012
                              • 398
                              Randy, are you getting a red background if you copy in Black & white mode? single color it and see if you can duplicate the problem. It looks like the SBU settings is corrupted or initialized.
