Pro C651EX skew
  • jhammond
    • Feb 2012
    • 9
    Pro C651EX skew
    I have replaced the stop gate, swing gate assembly, all new plastic cams, new drive (buckle) rollers, all new spring pressure bushings. I still get about 2mm skew when the skew adjustment is in the middle. It will straighten out when adjusted all the way to the right. Any ideas?
  • tjvincent
    • 280
    Re: Pro C651EX skew
    I would replace the rubber reg roller, I had one that i had to replace because customer ran coated paper.
    • jhammond
      • Feb 2012
      • 9
      Re: Pro C651EX skew
      The one right before the PTR? I can give that a try.
      • tjvincent
        • 280
        Re: Pro C651EX skew
        Correct, it's solid rubber from end to end.
