MP 2001SP scan to usb and print from usb problem
  • saa
    • Apr 2014
    • 10
    [Misc] MP 2001SP scan to usb and print from usb problem
    Hi
    I am not getting option scan to memory device while looking to use scan to usb.
    And at time print from usb also getting. I think any option need to enable in sp or trick.
    thanks
    • 37490
    Re: MP 2001SP scan to usb and print from usb problem
    The brochure indicates that these functions should be available for the MP 2001L and MP 2501L only, not the MP 2001. Check which model you have. For more information, check the Service Manual.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      You will require the optional HDD.
      • Polarbear
        • Feb 2012
        • 1070
        Don't let Ricoh fool you!
        Ever since the MP301 and such models were launched, Ricoh tried to sell us this idea of "HDD required".
        Well I proved them wrong. MP301SPF scan2usb.pdf
        This procedure works on all "chocolate and cream" machines (with or without HDD) from the MP301, MPC305, MP2001 to MPC3503, etc.
        To print FROM sd card or such you WILL need HDD though.
        Press the GREEN button!!
