Density Setting on Ricoh Alicio MP C4501
  • jetpack1976
    • Jun 2014
    • 15
    Dear Kind Souls,
    We have just installed a Aficio MP C4501 with PS kit.
    We were using a Cannon MFP prior to this machine. A newbie question please:-
    The canon MFP for print jobs, the density of the CMYK can be adjusted. In fact, it was very simple. even a simple density setting can be found either on the machine or on the computer print menu.
    For the love of God, I cannot find such a setting for the Ricoh machine. Where is the density setting if I want to print something darker or lighter? I cannot find the setting anywhere!
    Please HELP!!!!
    Thanks for reading
  • mikadonovan
    • May 2008
    • 2931
    Re: Density Setting on Ricoh Alicio MP C4501
    The density setting tab is on the left side of the screen.Make sure you are not viewing the simplified display or you won't have that option. Other color settings, bottom of the screen select Edit/Color>Color>Adjust Color>change your settings and select OK. In the PS3 driver, right click on printer, select printer preferences>print quality (from the top menu) or select printer properties>color management tab for more options.
    NEVER ASSUME ANYTHING
    • jetpack1976
      • Jun 2014
      • 15
      Hi Mikadonovan,
      Thanks for your prompt help. However, the settings tab you ask me to check out does not apply for printer. It only applies for photocopying. If I want to adjust the density for photocopying, then the "colour adjustment" tab on the screen works.
      I have also attached the printer preference pages. There are no density adjustment settings at all. For the color management tab, it is only for ICC profiles. There are no print density settings when can be altered.
      Any further help you can provide is much appreciated.
      • sandmanmac
        • 3981
        I'm by no means an expert in this area, but I did notice that you're using the PS driver for "Universal print" (for all models) rather than the PS3 driver specifically for your machine. I believe the "Universal" drivers often have limited options/ functionality vs. the specific PS 3 driver for your machine -In particular the feature that Mika has described
        I'd suggest downloading that instead, and giving it a try.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          http://www.ricoh-usa.com/downloads/p...41/mpc41en.htm
          right on sandmanmac! scrap the windows packed in unidriver.. Also in your screen shots you have color separations turned on, use ICC profile turned on, and did you load the icc profile for the ricoh??? if not you don't know what profile is being used for your color output...Also try something other than superfine for RGB and turn on smoothing for better output quality.......
          Mystic Crystal Revelations
          • jetpack1976
            • Jun 2014
            • 15
            Hi Guys,
            Thanks to all for your advice. However, sad to report, no dice. I have changed the driver back to the PS 3.0 version and I have also installed mac drivers to take a look. I can confirm 100% that there is no "density" setting. I cannot change the density setting either for colour or for black only.
            The main reason I want to increase the density is that I want a darker printout for some jobs. Last time, I can adjust for the Canon with a setting in the print dialogue. The printout would come out darker. It is not a matter of sharper text or better colour, I just want a blacker, darker printout for my purpose.
            Anybody can help?
            • mikadonovan
              • May 2008
              • 2931
              If you want more control over your color, you will need to invest in a fiery controller for your machine.
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 261
                [QUOTE=jetpack1976;425703]Hi Guys,
                • copytech,mike
                  CopyTech,MIKE
                  • Jun 2014
                  • 261
                  Originally posted by jetpack1976
                  Hi Guys,
                  Anybody can help?
                  Buy a Canon!
                  • copytech,mike
                    CopyTech,MIKE
                    • Jun 2014
                    • 261
                    Your full of shit. Every Canon copier allows you to adjust for density. So do all the other brands. This is a serious problem from Ricoh that doesnt know how to build a driver.
                    • copytech,mike
                      CopyTech,MIKE
                      • Jun 2014
                      • 261
                      Dear Kind Souls,
                      Please HELP!!!!
                      Thanks for reading
                      You cant find it because its not there. Not even on the full version of the printer driver. The only setting you can change on the Canon driver is the brightness setting which doesnt do alot.
                      • copytech,mike
                        CopyTech,MIKE
                        • Jun 2014
                        • 261
                        There is no overall density adustment while printing period and the density adjust on the copier will not work either because the printer driver will over ride it no matter what.
                        • sandmanmac
                          • 3981
                          5 posts in a 2 hour period on a 10 year old thread, and cursing at a long- time valued contributor!!???
                          WTF is wrong with you, idiot?!!
                            • 37489
                            I have already reported him
                            • copytech,mike
                              CopyTech,MIKE
                              • Jun 2014
                              • 261
                              You Calling people names and making rude comments.
