Desktopbinder pro
  • neilgreenhough
    • Dec 2007
    • 12
    Desktopbinder pro
    The Art of Diplomacy is The Art of Letting Someone Have Your Own Way....
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Data obtained by scanning originals can be stored in the hard disk of the machine using the Document Server, and the stored data can be used later. Using DeskTopBinder V2 Lite/Professional, stored data can be viewed, retrieved, or deleted with a client computer.
    • Jomama46
      • 2900
      In other words, you have what you need, Tech Support just doesn't know how to use it.
      Work with it.!
      sigpic
      A+; Network +; PDI+
      • neilgreenhough
        • Dec 2007
        • 12
        • neilgreenhough
          • Dec 2007
          • 12
          DTB Pro
          Work with it.!
          • neilgreenhough
            • Dec 2007
            • 12
            Work with it.!
            Question - when you shake hands with a salesman what is the next thing you should do?
            Answer - Count your fingers!!!!!
            • Jomama46
              • 2900
              How can you tell when a salesman is lying?
              His lips are moving.
              sigpic
              A+; Network +; PDI+
              • neilgreenhough
                • Dec 2007
                • 12
                whats the difference between a policemans night stick (truncheon in england) and a magicians magic wand?
                Answer - A magicians magic wand is for performing cunning stunts and the policemans night stick is for stunning c--ts.
                • wizardjimmy
                  • 39
                  is there any way for me to get desktoipbinder pro?
                  Customer: "Can you show how to print color in a black and white machine?" O.o
                  • KopyKat
                    Nurse Ratched of Repair
                    • Nov 2008
                    • 365
                    Haven't worked with DTB in a long time...but if you have the documents in DTB now, why don't you Print them to Document Server on the new machine. Yeah it's a lot of time and work. Better yet...sit the Salesman down in front of a computer and make him earn his commission.
                    sigpic
                    Relax! This firmware injection won't hurt...but it will take 45 minutes.
                    • rthonpm
                      • Aug 2007
                      • 2854
                      Similar to what KopyKat said, why not just open the web interface of the machine you want to transfer documents from, open the files and print them each to the doc server of the new machine? It may be a bit of a hassle if there's a lot of them, but with the file format converters installed you will at least be able to open them.
                      I just tested it with my two shop machines and it works. Just choose properties of the file you want to transfer, enlarge the image and print the PDF that opens to the new machine.
