MPC4000 NVRAM
  • GeorgeBest
    • Jul 2009
    • 526
    MPC4000 NVRAM
    Hi,
    Had to change the NVRAM on an MPC4000.
    did the SP5824 to download the data on an SD card, after the chance SP5825 for restoring the data
    So far, so good.
    After that turned the NIB and USB options SP5985 to "1" (on board)
    However; I get no printer and scanner function enabled !
    What's wrong here? Did the NVRAM change more times, always worked . . .
    Is there something I might overlooked ?? Can't see it
    someone ?
    Thanks in advance
  • Iowatech
    Not a service manager
    • 3930
    Re: MPC4000 NVRAM
    Where did you get the new NVRAM from? Sounds like it is bad.
    If you got the new NVRAM from Ricoh, look into getting warrantee replacement.
    If not from Ricoh, the dealer should also offer warrantee replacement for bad NVRAM if they are reputable.
    Good luck.
