Ricoh MPC3003 finisher curls first page on double sided staple jobs
  • Polarbear
    • Feb 2012
    • 1070
    We have an MPC3003 with the floor standing finisher installed. This specific machine, does, intermittently, curl over the first page of a double sided staple job (as per the attached photos).Eventually the machine stops with a misfeed condition.
    We have replaced the finisher (at the customer's request) and when the problem persisted, we even ordered and replaced the finisher with the booklet maker model, thinking that it might solve the problem.
    Thus far we have not been able to make any improvement, after specialists and field supervisors have spent days checking the machine and not coming away with a permanent solution.
    The customer (understandably) is getting very hot under the collar at present and is making demands about the permanent fixing of this issue.
    Can anyone assist with this, or has anyone come across this already?
    Press the GREEN button!!
    • 37489
    Re: Ricoh MPC3003 finisher curls first page on double sided staple jobs
    The problem is the paper.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      I agree!! try new paper of a different brand.
      Mystic Crystal Revelations
      • Polarbear
        • Feb 2012
        • 1070
        We have tried fresh paper from various suppliers. At this poi t I am thinking it has to do with the receiving tray somehow, as the paper collides with it on exit and most times only the first page turns over but sometimes a few turn over at once and then the machine stops with a jam condition.
        • Tonerbomb
          • Feb 2005
          • 2589
          Have you tried watching it with the door open and switch cheated? I would think that if you can watch it happen you would get a better idea of how it is occurring.
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            The 02s had a big problem with page curling into bridge units (folded corners), have not seen that happen to the newer 03s. I have seen this kind of curl on 03s with no finisher, replacing the paper exit (part # has recently changed) seemed to cure the problem.
            • Duke
              • Sep 2005
              • 19
              Is it only on duplex copies that it curls in the finisher? I have had a similar problem that originated from the duplex section of the copier.
              • Iowatech
                Not a service manager
                • 3930
                Sorry, that still looks like a poor paper problem, which is exactly what it has looked like for years.
                Then again, I'd like to see if there is something that we may have missed here.
                I'm guessing you have tried running the machine without any finisher attached. What happened then? Did the paper exiting the machine lay perfectly flat?
                Also, does that finisher use the rubber flappers (the kind of "L" shaped rubber parts that rotate counter-clockwise when viewed from the front of the machine) to draw the paper back into the finisher for stapling? If so, it is actually really important that you check their timing when you see something like this happening.
                  • 37489
                  You're located in what is most likely a high humidity region. Have you tried putting in the optional tray heater? If the problem seems to be more predominate in the morning, try storing the paper in a sealed container overnight. You could try turning the paper over. All paper has a tenancy to curl. If the side that has the natural curl side up in the tray, it will curl in the direction you show when running duplex. Usually the amount of curl is greater when the curl side is toward the hot roller or sleeve on the second time through the fusing unit.
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Thanks for the feedback guys! In total we have had 3 finishers on the 3003. 2 of the same and 1 booklet model with the same result ( which to me rules out the finisher but one never knows ).
                    • Debs1964
                      • Oct 2010
                      • 1693
                      It doesn't look like a damp paper problem to me as there is no significant curl or wave on the other sheets.
                      Does it ever occur with the first stapled set fed out? I am thinking that there could be excessive static in the paper which is causing the first sheet to stick to the previous stack as it's being fed out.
                      There are 10 types of people in this world, those who understand binary maths and those who don't
                      • Polarbear
                        • Feb 2012
                        • 1070
                        Yip Duke
                        only duplex staple sets. Single sided are fine. I am thinking it is a combination of paper curl and the angle of the receiving tray.
                        • Imprestik
                          • Aug 2012
                          • 297
                          Deb has hit it right on the head, it's a static issue, is your finisher grounded correctly but installing the correct earth plates.
                          Is it on carpet or is a board installed under it?
                          • Ricohguy
                            • Sep 2012
                            • 48
                            There are massive changes to the firmware on the two finishers this could be, I would guess that.
                            Could you let us know:
                            1) Model of finisher?
                            2) Jam code that is being thrown?
                            • Polarbear
                              • Feb 2012
                              • 1070
                              SR3140
                              Will have field tech pull smc report and report back
