Which Peripheral fits Which Ricoh Copier?
  • Lagonda
    • Aug 2008
    • 1649
    Does anybody have a comprehensive list of which DF, finisher etc. fits on which copier?
    I'm trying to purge our store of obsolete parts and when I search through the spare part manuals I can find which peripheral they fit. The trick then is work out what photocopier they go on. Then I can go through our Machines in Field list to see if I can toss the part or not.
    Any help greatly appreciated.
    Lagonda.
    • 37490
    Re: Which Peripheral fits Which Ricoh Copier?
    I do not think Ricoh has put out a peripheral to MFP spread sheet. Fastest method that I can think of would be to start from your machines in the field list. Check the Product Support Guide on each to see what peripherals they use.
    • Lagonda
      • Aug 2008
      • 1649
      .......... Fastest method that I can think of would be to start from your machines in the field list. Check the Product Support Guide on each to see what peripherals they use.
      The problem is our MIF list is over 10k boxes, I was just looking for a quicker way then fighting with our crappy data base accounting software package.
      • Athlontini
        • Jun 2012
        • 269
        SR790/SR3090 finishers can go on practically anything...
        Other than that obvious fact, I'll have to second Slimslob - check the PSG or service manual for models you've stocked a lot of and the Legend will list the peripherals.
        • nmfaxman
          • 1702
          Every service manual has a peripheral list in the beginning of the book including EDP numbers.
          Create a spread sheet and compare.
          Older machines have it on the CD with a cross reference that is printable.
          PM me if you need it.
          • redneckstylin
            • Sep 2011
            • 173
            BU 3000 bridge unit will fit c2000 c2500 c3000 c3500 c4500
            BU 3030 bridge unit will fit c2800 c3300 c4000 c5000 c3001 c3501 c4501 c5501 / mp4000 mp5000 mp4001 mp5001
