Hi guys.. I'm facing this issue. Already change pcu unit. Sc code still appear. Please give me some advise.
Sc 491.
Re: Sc 491.
From Gooses Guide:
B230/B237 SC 491 Dev bias output error, High voltage power pack defective
B230/B237 SC 491 Dev bias output error, Drum or developer unit defective
B230/B237 SC 491 Dev bias output error, Check harness and connections
I'd be fitting a new PCDU before I went swapping out boardsComment
Re: Sc 491.
SC491 Details :
High voltage power: Drum/ development bias output error
Symptom:
An error signal is detected for 0.2 seconds when charging the drum or development.
Possible Cause:
- High voltage leak
- Broken harness
- Defective drum unit or development unit
- Defective high voltage supply unit
Troubleshooting Procedures:
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.Comment
