3224C Display
  • SloopJohnB
    • Dec 2014
    • 4
    3224C Display
    Hello
    Had an accident over the weekend and cracked the display screen on the machine. Is there a company I can get a second hand unit from as I have tried Ricoh here in New Zealand, no luck.
    Thanks for any advice.
    John B
  • sandmanmac
    • 3981
    Re: 3224C Display
    Not sure if you mean just the touch panel (glass) or the whole LCD screen?
    The Original P/N for the glass was B213 5222, and the LCD B213 5225
    Either way, both were common among several different models (Below). Maybe a dealer has a parts machine with a good LCD and/or touch screen.
    Otherwise ebay (?)
    • Ricoh Aficio 2035
    • Ricoh Aficio 2045
    • Ricoh Aficio 3025
    • Ricoh Aficio 3030
    • Ricoh Aficio 3035
    • Ricoh Aficio 3045
    • Ricoh Aficio MP 2510
    • Ricoh Aficio MP 3010
    • Ricoh Aficio MP 3500
    • Ricoh Aficio MP 4500
    • SloopJohnB
      • Dec 2014
      • 4
      Re: 3224C Display
      I believe its only the glass as all the icons are still shown under the glass but I can't change any of the setting. I have not removed it from the machine yet but will post a photo soon.
      • Polarbear
        • Feb 2012
        • 1070
        Re: 3224C Display
        Yip it is only the touch panel "overlay" that is cracked. Thankfully the lcd below is still ok. As per the previous post, you can use any one on the models listed if you can find a second hand op panel.
        It is a bit of work as there are plenty screws holding the circuitry to the back of the op panel, and all these need to be remove to extract the touch panel glass.
        When you re-assemble, just be mindful that the touch panel is resting between locating "dots" that are in each corner of the actual op panel frame. If this is not the case, the glass will crack when you tighten the circuit boards back onto the op panel frame. Basically the glass needs to lay flat on the op panel frame and not raised in any of the corners.
        Press the GREEN button!!
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: 3224C Display
          Last part number I knew was H310 9900. Don't know if it's still valid.
          Hit it.
          • SloopJohnB
            • Dec 2014
            • 4
            Re: 3224C Display
            Can anyone advise where I can buy an overlay?
            • Luther
              • May 2006
              • 682
              Re: 3224C Display
              EBAY. pretty inexpensive also
              • Zaxxon
                • 608
                Re: 3224C Display
                Remember to mount it with the correct side up.
                Please start you post with brand, model, problem.
                • sandmanmac
                  • 3981
                  Re: 3224C Display
                  I believe I gave 2 suggestions in my first reply - including Ebay
