LD 425C Printer: Paper Tray Status shows by-pass at 5 1/2 x 8 1/2 with a key
  • Logged-on
    • Sep 2010
    • 197
    When we try to copy letter paper from the bypass only a 5.5 x 8.5 image is produced. All the paper tray settings are correct, except with the printer screen. When you select the printer screen, the display shows the by-pass tray set for 5.5 x 8.5 with a small key next to the setting.
    Can someone please explain how to change that setting? I've been through the service, and operation manuals, and can not seem to find a solution.
    Thanks, Marc
  • LNorris
    • Sep 2008
    • 645
    Re: LD 425C Printer: Paper Tray Status shows by-pass at 5 1/2 x 8 1/2 with a key
    check your default settings under user tools to see if someone has set that instead of auto detect
    • Logged-on
      • Sep 2010
      • 197
      Thanks for the reply. The Bypass setting was set at 5.5 x 8.5, which we changed to auto detect, and that is displayed on the control panel. Next we tried changing that to 8.5 x 11, which is displayed on screen as the Bypass paper size, but when we make a copy, it still only prints a 5.5 x 8.5 image on the paper.
      We can get all the settings to show properly on the display, and if we use the "#" key to set paper size manually, then the image prints fine. It's only after doing a "clear modes" then make a copy from the bypass, that only a partial image is printed.
      Thanks again,
      Marc
        • 37489
        Are you running the paper from the bypass as Short edge Feed or Long Edge Feed?
