Dead MPC 6502/8002.
  • Zaxxon
    replied
    Re: Dead MPC 6502/8002.
    Glad to help, good luck!
  • Timmytronic
    replied
    Originally posted by Zaxxon
    [ATTACH=CONFIG]28037[/ATTACH]
    [ATTACH=CONFIG]28038[/ATTACH]
    [ATTACH=CONFIG]28039[/ATTACH]
  • Timmytronic
    replied
    Originally posted by Timmytronic
    Hi. I have had a look and I can't see it. The manual is crap on these newer machines. Is the ac drive board just behind the internal RIP once swung out then behind the main board? This is my first 8002 I am normally on 7501's etc.
    I have found it....Doh. One of the boards I took off and put to one side. Thank you.
  • Zaxxon
    replied
    I mi have had a look and I can't see it. The manual is crap on these newer machines. Is the ac drive board just behind the internal RIP once swung out then behind the main board?
    I remember it as lower left from the back, behind some boards and a little hard to get.
  • Timmytronic
    replied
    FU105 on the AC Driveboard
  • Zaxxon
    replied
  • Zaxxon
    replied
    thank you. I have checked the fuses with a meter and all seem fine, is it one particular one?
  • Timmytronic
    replied
    Nope only a fuse and one board.
    The parts# for EU models:
    Fuse D1389906
    PSU D1389907
  • Zaxxon
    replied
    hi. Do they replace both boards or are they classed as one?
    Fuse D1389906
    PSU D1389907
  • Zaxxon
    replied
    Don't know if it is free in your country, but worth investigating.
    Turn machine off - remove power cord - press and hold power off button - Now safe to remove boards without getting zapped
  • Timmytronic
    replied
  • Timmytronic
    replied
    Hi. Thank you. Does that mean they will do a swap for free? I thought it was a case of letting the power go before I take it out but thank you.
    Tim.
  • Zaxxon
    replied
    Hi. I have a dead MPC 8002. Customer went to use it this morning and it won't switch on. I have had a look and it must be the PSU. Before I pull it all apart has anyone had this and found it to be something else silly or a common fuse blowing. I have checked the plug and power :0)
    thank you you for anything.
    Tim.
    Hi Tim
    Ricoh has a modification program running for this model regarding PSU failure/replacement.
    Be carefull to use the correct shutdown process or you will get an electrical shock when grabbing the PSU...
  • Timmytronic
    started a topic Dead MPC 6502/8002.
    Dead MPC 6502/8002.
    Tim.
