printing problem with aficio mp w2401 !
  • jakani
    • Dec 2014
    • 147
    i have a problem with printing some pdf and tiff files on a machine aficio mp w2401 , it's either the file printed small size in middle of A0 or it's cut and printed on several A0 ,
    what i want is that the file printed complete on A0 paper
    have anyone faced this problem before ? is there any ricoh software that can manage those kind of prints ?
    any helpful suggestion would be great
    thanks in advance
  • Sashko
    • Oct 2009
    • 110
    Re: printing problem with aficio mp w2401 !
    Change the settings for "Memory usage" to "Font priority" in the "Printer Features" from "User Tools" or WIM.
    • jakani
      • Dec 2014
      • 147
      ok thanks for reply , i will try it and see
        • 37376
        Also, when you are printing PDF from Adobe, check that the paper size is set correctly and that fit to page is checked.
        • jakani
          • Dec 2014
          • 147
          i checked the paper size and also fit to page and the same result !
          before the ricoh aficio my client has a xerox machine and had the same problems with some tiff and pdf so the xerox gay installed a program called "xerox plotter" that you can put the file on it and it printed normally i wonder if ricoh have some soft like this !
            • 37376
            I don't think Ricoh has any such software. You might try loading Ghostscript. You can also try using IrfanView with all add ins.
            • jakani
              • Dec 2014
              • 147
              i changed the settings for "Memory usage" to "Font priority" and steel have the same problem
              i try to take my laptop and try infranview !
              btw here is an example of a pdf file that they could not print
              • Sashko
                • Oct 2009
                • 110
                btw here is an example of a pdf file that they could not print [ATTACH]28319[/ATTACH]
                Try to print directly "PDF Direct Print" or "Webprint" "http://(machine's address)/webprint/index.html
                • Sashko
                  • Oct 2009
                  • 110
                  Another way, please use Synchro Cut instead of Preset Cut.
                  User Tools/Counter > Extended Feature Settings > GL/2&TIFF > General Settings > Cut Method > Synchro Cut
                  • jakani
                    • Dec 2014
                    • 147
                    thank you for infraview i tried it , and i was able to print in the whole page but it's stretched ! and thanks to you i found that i want to print a long page and thats may solve my problem !
                    and thank you slimslob for your suggestions i already tried web print tool with no result , and also this morning tried to change to Synchro Cut and the problem still the same !
                    now what i want is to print a longer printing than A0 ,i don't know how to do it ? any help would be great thanks in advance
                    PS : when i try to change the paper setting from my laptop , i get a message in plotter saying that paper parameter are not correct do you want to reset the job .... something like that !
                    • jakani
                      • Dec 2014
                      • 147
                      hey everybody
                      i found a way to print in long print paper
                      for example for pdf file i click on file>properties then i look for page size and it's something like 144.46*32.66 , i write it down then in printer properties i choose custom paper size an i enter that 144.46*32.66 then i could print it perfectly with irfanview and foxit reader also ,
                      • khattab.al.masry
                        • 212
                        THANK YOU SIR!
