Re: A heads up on Java
FInally got mine going thanks to a Ricoh tsm I have good contact with. He provided doc's that I couldn't find for the set up.
A heads up on Java
I don't know if that's a Phase 2 model or not... never heard the term before.Leave a comment:
Have you run into the SOP phase 2 yet??????? Still fighting with the smart device connector on iOS and Droid..............Leave a comment:
A heads up on Java
Howdy,
Just recently we have discovered that the newer models that have Java 10.x, 11.x, and even 12.x are extremely picky about the version of Java versus the version of the System/Copy firmware.
if you weed through the readme file included with each Java update, you will find this is explained: each version of Java shows the required version(s) of System/Copy.
There will also be the recommended settings for the Heap and Stack sizes. HINT: Do NOT be a hero and max these out, it has an adverse effect.
Also found out yesterday that version 10.20 is now out, but is erroneously labelled 10.19. :>}
Joy, joy.Tags: None
