MP C2500 scanning issue
  • mazzi
    • Jun 2010
    • 10
    Hi,
    I have a problem with scanner on this machine. When a customer is scanning in full color scans are perfect, but it all changes when it comes to bw scanning. Scan get dots on scan file all over the paper (attached files)
    So far i've cleaned optics, firmware upgrade
    Any suggestions are welcome =)
    BR,
    t.
  • Max
    • Oct 2011
    • 556
    Re: MP C2500 scanning issue
    Try scanning with a different filter. Text,picture,map instead of text/photo mode.
    • freginold
      • Sep 2010
      • 102
      Use the Check Modes button to see if any settings have been changed -- Pale, Generation, etc.
      Config page instructions for copiers, printers, & fax machines
      • mazzi
        • Jun 2010
        • 10
        ok i solved the problem. I switched off auto color selection on scan features and set up color scan only and its now working ok
        Thank you all
