9025b no feed jam
  • Iowatech
    replied
    Re: 9025b no feed jam
    Kind of an off the wall suggestion - check user tools to see if the tray is set up correctly.
    replied
    Check the paper end feeler. If it is not properly mounted, it will not drop into the slot in the lift pan. The machine will see this as paper in the tray.
  • coolcat467
    replied
    Yes I did. When the tray has paper in it, it feeds beautifully. The problem happens when the tray runs out of paper and still senses paper in the tray. It basically tries to feed nothing.
  • copyaction
    replied
    Did you check in the back for the paper tray switch that gets knocked out of place?
  • coolcat467
    started a topic 9025b no feed jam
    9025b no feed jam
    Hello, I have a D018 (Savin 9025b) that is coming up with a tray 1 no feed jam (003). I have figured out what is causing this however I don't know how to fix it. When the tray is out of paper it still thinks there is paper in it. I have replaced the paper end sensor and swapped all components from tray 2 which works like it's supposed to. I don't know what else to try. Any suggestions would be very much appreciated.
    thanks!
