paper jam cannot be reset in spc811 printer
  • BATA
    • Mar 2012
    • 27
    [Jamming] paper jam cannot be reset in spc811 printer
    hello friends
    in printer ricoh spc811 , while printing the main power is gone down then returned after a while , there was a paper jam occurred, removed as normal ,the signal is still the same , machine said search in C, that means fuser area , we checked ,nothing wrong , does it a matter of bad sensor or something happened in the
    boards , or stupid problem
    • 37458
    Re: paper jam cannot be reset in spc811 printer
    It could be a bad sensor or a small scarp of paper setting on the sensor. It could also be a bad door switch. If the printer does not detect that the door has been opened and closed, the jam indication will clear.
    • Richariri
      • Dec 2013
      • 163
      I agree with everything slimslob said.
      I just wanted to add that you sometimes need to open and close the little door at the top of the duplex unit to clear the jam message. (see attachment)
      I constantly forget this and start to think the worst.
      • BATA
        • Mar 2012
        • 27
        tomorrow i will check , thank you all
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          I've had a faulty fuser connector on a SPC811DN at a school where the pins had been damaged / pushed in, that also displayed as a jam at C that wouldn't reset.
