ricoh mp4000 coping color-originals problem
  • vga_man
    • 78
    HELLO!
    i've ricoh mp4000 . i had made cleared memory after that i lost scanner settings
    i mean that when i COPY color original ->appears white sheet and only black text
    red green blue are not seen on the copy
    is this is a copier problem or scanner?
    i've tried to print from computer and the image too clear, but coping function is not working with colors(RGB)
    please help me to restore scanning settings or fix the problem!
  • teebee1234
    • Jul 2008
    • 1670
    Re: ricoh mp4000 coping color-originals problem
    I give up...
    • Polarbear
      • Feb 2012
      • 1070
      Originally posted by vga_man
      HELLO!
      Is this an mp or MPC4000?
      Press the GREEN button!!
      • vga_man
        • 78
        MP4000 B&W print and supports color scanner
        • Elmo
          • Feb 2010
          • 541
          Why did you think it would be ok to do a memory all clear an still expect the machine to work properly
          call a qualified tech he will fix it
          I Used To Live To Fix Things Now i Fix Things To Live
          • vga_man
            • 78
            Originally posted by teebee1234
            I give up...
            i scanned color document using scanner and printed it from PC although colors are not seen on the printed paper as a gray scale - it's white
            only black words
            background are not seen on the copy but seen on the pc true color image
            when printing any other image, which scanned from other scanner it became gray scale copy
            anyone know how could i solve this problem
            • vga_man
              • 78
              i called him he entered sp mode then increased developer bias ... problem not solved
              • vga_man
                • 78
                attached scanned original example
                • Elmo
                  • Feb 2010
                  • 541
                  By doing the memory all clear you have defaulted all the values within the machine
                  the machine needs to set back up correctly to the values on the machine birth certificate (mainly the scanner read settings)
                  you are not a tech and you are messing about with the machine service settings
                  providing untrained people with the information on how to resolve this issue would likley only cause more problems
                  my best advise is to call your tech explain to him you have done a memory all clear on the machine
                  and ask him to reinstall the birth certificate values (if you have it) into the machine
                  • vga_man
                    • 78
                    I think that in Egypt there are not real tech, because i already called him.
                    he came to me but nothing done...
                    please provide me with steps if it is not the secret of job
                    thanks you for your favor...
                      • 37490
                      Defaulting all values means User Tool and application defaults set from the application screen. It is probably also scanning as TIFF instead of PDF. How to change the values is in the Operators Manual. You should be able to look that up yourself.
                      • vga_man
                        • 78
                        problem solved i changed 4450 Scan Image Path Selection SH on/off to 1 value.
                        but there are one problem
                        after restarting machine value automatic returns to (0)
                        how to fix this value to be 1 forever??
                          • 37490
                          It is not an SP setting that you need to change. After you have changed the required value you must then Register the Default. Again it is in the OPERATORS manual not the service manual. Scan Type, Resolution, Scan Size are Operator settings that the user can change as desired.
                          • vga_man
                            • 78
                            ok it's the solution to register the settings : but is the 4450 value will registered with this method?
                            @all I'll try that replay
                            Registering the Initial Display's Default Functions
                            thank you alot
                              • 37490
                              thank you alot
                              No. Register the defaults settings only stores user settings. You have to change the Scan Settings in the scan function screen then register the defaults. It is all operator functions.
