RICOH AFICIO MPC305SPF Error code SC370-00
  • cucuklotz
    • Mar 2007
    • 611
    Hi First time servicing this machine, Customer called with code SC370-00 error,I purchased service manual and looked up code.If I understood manual correctly(and Im not sure I have)this seems to be id sensor issue with a number of possible causes,Am I correct about this? and if so can you offer some advice on what you have experienced with this code. Im trying to find reset procedure,but this manual is huge, THANKS FOR ANY POSSIBLE HELP. ANDY
  • Zeldaman
    • Mar 2011
    • 946
    • cucuklotz
      • Mar 2007
      • 611
      Re: RICOH AFICIO MPC305SPF Error code SC370-00
      HI Thank you for helping ,I will try that. Andy
      • Zaxxon
        • 608
        Check density of CMYK - The laser units tend to "pop up" on this model causing odd images/density.
        Easy to check, on screw and the lid is of, be careful not to break the paper thin cable attached to these units.
        and good luck.
        Please start you post with brand, model, problem.
        • cucuklotz
          • Mar 2007
          • 611
          Hi I trhought I .read somewhere that this level service error is not reset thru SP,but with power off and on.Does anyone know if this is correct? Thanks Andy
          • Zaxxon
            • 608
            This sc reset itself when the problem is solved.
            • salo ventura
              • Aug 2007
              • 11
              hello< I have a the same problem Ricoh Sp 830dn. send me Error code SC370-00, I can't not fix the problem. please send me the service manual.
              “Perseverance is not a long race. It is many short races one after another.”
