Lanier MP 5002
  • 88hawkfan
    • Jun 2014
    • 76
    Lanier MP 5002
    I have a Lanier MP 5002 with light copies. I've replaced the developer unit, developer, drum and charge roller, cleaned out the laser unit, updated the firmware, and replaced the entire transfer unit to no avail. This is easily the worst series of machines Ricoh has ever produced, anybody come across this or have any idea of what's wrong with this piece of crap? I'm at my wits end with this series and its predecessors.
  • Bantams
    • Jun 2012
    • 603
    Re: Lanier MP 5002
    Paper Transfer roller next then can you post some pics that would help
    • Debs1964
      • Oct 2010
      • 1693
      Re: Lanier MP 5002
      There isn't a paper transfer roller on this model, only a transfer belt
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • Debs1964
        • Oct 2010
        • 1693
        Re: Lanier MP 5002
        There are 2 HV connectors onto the transfer belt unit, are you sure these are plugged in the correct way round, if these get swapped over then you will get faint copies
        • 88hawkfan
          • Jun 2014
          • 76
          Re: Lanier MP 5002
          Brand new transfer unit.
          • Debs1964
            • Oct 2010
            • 1693
            Re: Lanier MP 5002
            Are prints and copies faint, or just copies?
            • brunot
              • May 2012
              • 148
              Re: Lanier MP 5002
              Check the development bias voltage - the high voltage supply board applies a bias of -560V to the development roller.
              • fbkhan3
                • May 2012
                • 421
                Re: Lanier MP 5002
                Meter the continuity at drum shaft most of the time bad ground will cause this issue.
                what if you have solid print on drum but not properly transfer on the paper which you need to check Transfer belt section.
                I have had the Toner Motor gone bad on this model a few months ago as well but of course you will get toner end indication after few copies.
                Also need to clean the Mag roller shaft lot of toner build up will cause poor bias voltage.
                what is the vsp and vsg readings?
                Regard's
                Last edited by fbkhan3; 03-28-2015, 06:49 AM. Reason: didn't read the thread properly
                • PA3040
                  • Jun 2014
                  • 171
                  Re: Lanier MP 5002
                  1.Stop the machine while printing by guessing that the paper mid of the transfer belt
                  2.Check the image on both drum and the paper
                  3.If the image on the drum more dark than the image on the paper, then you can decide the section of frailer
                  • Bantams
                    • Jun 2012
                    • 603
                    Re: Lanier MP 5002
                    Note to self don't reply to posts on a Friday Night
                    • trc
                      • Jan 2007
                      • 95
                      Re: Lanier MP 5002
                      In one of this beauties....have to change ld board.....also could be drum earth or the magnetic roller issue....if you have other machine working well change laser unit first....then developer unit.
                      • vargue
                        • Oct 2011
                        • 404
                        Re: Lanier MP 5002
                        what happened when make forced toner supply it's improve or the same issue .or bad ground
