MPC 2800 power supply to a mpc3300. .compatible? DO23 DO25
  • fshead
    • 2376
    hi
    i just went to a mpc2800 i placed 2 weeks ago where the touch screen is dead,or black.
    GOOSE GUIDE SHOWS
    display goes black - update scanner fw to 1.24 or higher & system fw to 1.24 or higher
    No display - check for input voltage, replace PSU as needed
    no display - cracked soldering on polygon mirror motor pcb
    no display - update LCDC fe to 1.09 or higher
    swapped the control panel out with my shop machine wth all updated firmware after cking bypass area for pinched wire.
    no change. cked poly motor.ok
    i cked all fuses on power supply and cked connectors but still the same.
    does a mpc3300 power supply work in the mpc2800?
    any other things that one would check?
    the control panel leds seem to work and after 50 seconds it switched to printer and some alert led on.
    thnx in advance
    • 37489
    Re: MPC 2800 power supply to a mpc3300. .compatible? DO23 DO25
    If you can access the machine with WIM, see if there is a polygon motor error.
    • sandmanmac
      • 3981
      Originally posted by fshead
      hi
      Are you sure your issue isn't the very popular SC202 that you can see by shining a bright light in the display, where the Polygon motor takes out the BICU?
      If so, they must be replaced as a set, or the motor will short out the BICU again.
      Luckily I've never actually run across it.
      • Debs1964
        • Oct 2010
        • 1693
        What, never???? I have had this fault so many times.
        As Sandmanmac says, if this is SC202 (if you can access the WIM you'll be able to confirm this) then you must replace the polygon mirror motor and BICU as a set, if you just replace the BICU then you'll fry a second one if the faulty motor is still there
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • Gift
          • Mar 2011
          • 2459
          All this SC 20x related stuff is just valid if the screen backlight is missing but LCD still working (check with a lamp - it'll be hard to recognize):
          Unplug the polygon motor, trurn off the machine - if the panel comes back the BICU isn't fried -> just replace the polygon motor and you're good to go.
          If the panel doesn't comeback -> the BICU is probably fried as well (happens in most cases) - you can either try and fix the PCB (search forum) or swap the BICU and polygon motor. As statet before: Never use a healthy BICU with a faulty polygon motor.
          • Debs1964
            • Oct 2010
            • 1693
            My understanding was that the polygon mirror motor causes the SC202, but it's the BICU that causes the blank display, hence why both are replaced at the same time. I can't see that a faulty polygon mirror motor would give you the display problem
            • LNorris
              • Sep 2008
              • 645
              ive had a bad hard drive do this to me as well....the 220/202 code showed on op panel, but i had swapped everything and no change, unplugged hdd and all restored...reformatted hdd and all was well
              • fshead
                • 2376
                thnx
                i cldnt get the ip address as the IT guy has everything on lockdown..Outside and hard to reach.
                cant access ports on printer configuration.
                honestly i never logged on a copier in WIM wth a sc code.till now wth a mpc2050 i have blowing random sc565 code.
                now i see it Call Service Center:SC565..
                with regards to bicu brd and poly motor,,
                can i swap the mpc3300 parts into a mpc2800?
                thnx
                • fshead
                  • 2376
                  fix the PCB (search forum)?
                  i did a search mpc2800 bicu and found lots on dreaded sc202 code and what looks like my issue..
                  didnt see reference for fix the brd?
                  was this for repairing bicu or plygon motor brd?
                  does anyone know what goes on polgon motor?
                  thnx
                    • 37489
                    thnx
                    thnx
                    IO f IT isn't available and you cannot check the IP address in the print driver on a computer, follow Sandmanmac's suggestion and shine your flashlight across the display.
                    • fshead
                      • 2376
                      thnx
                      im familiar wth what using the flashlite from fixing laptops wth bad backlight inverters or invert brds..
                      i have a call in to IT guy who should get back to me b4 i arrive on site.
                      my guess is the polymotor and or BICU brd.
                      i dont have more than 10 of these out there so this is my 1st time seeing this issue.
                      kinda wish i had researched this b4 taking the look yesterday.
                      i knew the lcd displays had issues and just figured it wld be a quick swap and fix..
                      • sandmanmac
                        • 3981
                        thnx
                        Props go to "Polarbear" on this. I saved a copy of his findings some time ago, for my future reference:
                        SC202 - MP C2800_4000 - Solved.pdf
                        • fshead
                          • 2376
                          well i got everything running again.
                          turned out to be the sc202 error wth both the polymotor and BICU needing replacing.
                          i culd not read dead display wth flashlite and IT guy gave me the wrong ip address
                          but after messing around on customer laptop i found it and got the sc202 code in WIM.
                          THNS TO ALL.
                          does the new polymotor have a different part number?
                          thnx
                          • Sashko
                            • Oct 2009
                            • 110
                            [ATTACH]28654[/ATTACH]
                            I fix BICU board in same way.
                            I made a schematic diagram of BICU. This helps to understand how +24V redistribute through BICU board and what will happen if it short to ground (SC202).
                            SC202_Scheme.pdf
                            SC202_HowTo.pdf
                            • ruben
                              The New Guy
                              • Oct 2012
                              • 1203
                              THNS TO ALL.
                              thnx
                              AX060396 is the new part no.
                              See: rd025055a.pdf
