Why would formatting the hard-drive on this Ricoh Aficio 2022SP fail if the hard-drive is good? Thank you for any help given.
Ricoh Aficio 2022SP
Re: Ricoh Aficio 2022SP
A PC is much more tolerant of bad clusters than an MFP. A PC will mark a cluster bad and add it to the redirection table which lows a rather large number of redirection entries. The only sectors on a PC are critical are the boot sector and the sector that contains the primary partition table. On a MFP, the format utility merely erases the existing directory structure and write a new one. It will not tolerate any errors in the directory structure. It will also tolerate a very number of entries in the redirection table.Comment
