MP C5501 Color Registation
  • ABS tect
    • Sep 2013
    • 511
    I have a MP C5501 that came in with everything reset in the SP Mode. So using the birth certificate i have manually re-entered every number back in. However, still after all that was done, the color registration will not be completed and as a result when i print out the auto color calibration, the black and cyan bars are out of line. I have already replaced the transfer belt as well as all 4 PCU's with ones from a machine that is working perfectly, so I know that it is not those. So is there any manual adjustments that you can make to bring the colors into registration? Or anything period to get the colors aligned?
  • copier tech
    • 8144
    Re: MP C5501 Color Registation
    Did you run line postition ajust? SP2-111-3 then SP2-111-1 (C then A)
    • ABS tect
      • Sep 2013
      • 511
      Thank you! That did it!
