MP C4000 fuser not setting properly
  • ABS tect
    • Sep 2013
    • 511
    We are replacing the fuser in a MP C4000 and when we put the new fuser in, it said that the fusing unit was not set properly. We have tried 3 different ones, 2 from a MP C5000 and one from a Lanier ld540c, neither worked. All three look identical to the one in the 4000 but it won't take it for some reason. Is there a reset code for the fuser or some reason why those are not going in?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP C4000 fuser not setting properly
    No code to reset this message, it all done automatically.
    Make sure the connector on the inside of the machine has not broken.
    See: http://www.copytechnet.com/forums/ri...r-message.html
    • Bocfus
      • Dec 2014
      • 16
      I've seen the sensors on the left hand side inside copier get knocked out of place. Doesn't recognize fuser.
      • C.Vallon
        • Jan 2015
        • 70
        You mentioned you tried 3 different fusers and all had the same issue?
        As recommended, I'd check to make sure no sensor was knocked loose. Beyond that, check the pins in the connectors on both the fuser(s) and the MFP? Make sure they're not bent and are actually making a secure connection, that could cause the error message to appear.
        Let us know what you find.
        • C.Vallon
          • Jan 2015
          • 70
          Also, off thought for a shot in the dark. If after checking pins and sensors don't work, you may need to trace back the wiring from the connector on the MFP side, make sure the wires are not pinched or damaged. This is a slight chance, but being that you tried more than one fuser and if the pins and sensors are fine, it may be a wiring issue with the MFP, couldn't hurt to check?
          • ABS tect
            • Sep 2013
            • 511
            Yea I checked all the pins and such and everything looks in place. And I can check the wiring on the mfp but what is weird is when I put back the original fuser, it fires right up. So that makes it hard to believe its the wiring.
            • C.Vallon
              • Jan 2015
              • 70
              Ok, hmm. You did mention you used other fusing units from other machine models? Check the parts catalog to make sure the Fusing units are actually the same unit? Could be that even though they look the same, they may not be identical, if so that could cause it to throw the error code.
              I'll attempt to think of other solutions too, that's the first thing that comes to mind when you mention putting back in the original, it fires back up. There may be a compatibility issue?
              • ABS tect
                • Sep 2013
                • 511
                Right, that's exactly what I was thinking. And I'm checking on that. And if that's the case, and we don't have one of those machines, I will probably just rebuild the original fuser and be done with it. Just strange because I have switched fusers in and out all the time in those machines, never checking the model. Thank you!
                • C.Vallon
                  • Jan 2015
                  • 70
                  Good luck, let us know what you find.
                  Though at this point, if you have the ability to rebuild the original fuser, I'd probably just go with that. Being that you can confirm that one is at least "seated" properly. Most likely less expensive to go that route as well.
                  • anothertech
                    • 1769
                    This happens when we use fusers from the printer models in the copiers, we have to swap a wire in the fuser connector. Could this be the same cause here? I dono, maybe
                    • ABS tect
                      • Sep 2013
                      • 511
                      You have to swap a wire on the actual fuser? Could you explain that a bit more?
                      • JayPaul
                        • Oct 2012
                        • 305
                        Am I allowed to say this on here?
                        For the printer version, you have to remove the fuse thats just on a white clip, from the bottom of the fuser. Then pull out the connector and swap 1 red wire over 1 notch. I cant exactly say what one on here but what you are describing sounds like you may be using the printer version of the fuser without modifying it
                        • PA3040
                          • Jun 2014
                          • 171
                          check the following
                          5803 Input Check
                          046 Fusing Unit Set Set (Bit1) Not set (Bit1)
                          • mohan
                            • Oct 2013
                            • 86
                            Sounds like the fuser set sensor has become dis-lodged. Happens too frequently on these.
                              • 37487
                              Originally posted by PA3040
                              check the following
                              5803 Input Check
                              According to my service manual, 5803-046 is ITB New Unit Detection.
                              Input items for the fusing unit are as follows:
                              5803-083 Fusing Destination Detection Japan, Europe, Taiwan
                              5803-084 Fusing Destination Detection North America
                              5803-087 Fusing New Unit Detection
                              5803-088 Fusing Unit Detection 1
                              5803-089 Fusing Unit Detection 2
