Ricoh MP C4500 Feed assembly
  • copyman20
    • 207
    Greetings Folks
    is it possible to put an MP C4501 feed assembly into an MP C4501?
    Thanks in advance
  • LarryTech
    • Apr 2015
    • 11
    Re: Ricoh MP C4500 Feed assembly
    Originally posted by copyman20
    Greetings Folks
    Thanks in advance
    Did you mean a mpc4500 feed unit in a mpc4501 or did you mean a mpc4501 feed unit in a mpc4500?
    Or did you mean to say something entirely different maybe.
    • sandmanmac
      • 3979
      Incredibly risky! Have a fire extinguisher at the ready!
      • copyman20
        • 207
        going from a 4501 to 4500.
        • Gary Bowen
          Bowdog
          • Mar 2008
          • 250
          The C4501 uses a Paper Feed Belt Assy instead of a Pick Up Roller. I know the C2800 Feedhead Assy works in the C4500.
          • redneckstylin
            • Sep 2011
            • 173
            i swap those stupid feed belts out for the af03-0090 tires hate those feed belts they break and customer is down
            • impetus73
              • Mar 2012
              • 75
              I use the red AF03xx85 rollers on all models from 2500 to 5502.
              • JonManchester
                Technician / Shop Manager
                • Aug 2013
                • 103
                Hey Impetus73 what is the yield difference between the AF03-0085 and the AF03-0090 tires. According to the price, the 0085 tires to replace a set is less than half the cost of replacing a set of 0090 tires.
                Live for something or die for nothing.
                • tufbnme
                  • 493
                  Yes, and replace the stinkin pickup belt with the urethane roller.
                  • Counsel
                    • Aug 2011
                    • 529
                    Im not sure if they work, the 4501 uses the same parts in the feed construction as your B&W MP5000 and MP4000 models the D009 parts with only a few of the B223 part numbers most of which only reference to the same as the MP4000 series. The parts in the manual for the c4500 dont even have the same numbers for the guide flaps so not really sure they would cross over, plus the c4500 was noisy as hell they always sounded like paper was being shredded or crinkled when it fed i think they even did a design change in there on that one.
                    You could probably pull a MP5000 or LD050 we use lanier numbers. As for the rollers i concur with dropping that crappy belt thing and putting on the 85s or 90s instead.
                    • copyman20
                      • 207
                      Thanks e everyone for the answers. the feed assembly for the 4501 and 4500 are different. One will not work in the other.
                      Thanks again everyone
