Re: ricoh fax option compatibility question
The MP C2030 has its own Fax Option (Type 2530 Fax/EDP Code 414630) and the C2050/C2550 uses Type 2550 (EDP Code 414925). Good luck.
i hear you but i have seen a lot more mpc2030 s wth fax..
as is i put one in my spare mpc2050 and it comes up in user tool,service and when i pull the blank cover over
where fax button should be and hit switch it works..
now i didnt connect a phone line yet but as long as it didnt blow up any boards im happy right now..Leave a comment:
Same product family, different speeds. The 2030 an 2530 are limited feature models. They do not come with HDD and are limited on address book size, a couple of other options that require HDD.Leave a comment:
hi
i saw that but it does fit in there and i just bought some
3 volt battery holders that solder on to the small fax brd"mbr brd"??
and then you just insert a new battery..
will post a pic for those that might need to change the 3 v lithium battery
down the road.....Leave a comment:
Different product codes, so most likely won't work.Leave a comment:
anyone know if a mpc 2030 fax option work on a mpc2050?mpc2550?
im going to pick up 3 volt battery holders to fix a couple of mpc2030 fax brds and could use them wth a few mpc2050/mpc2550 i just placed.
thnx in advanceTags: None
