hi i have an issue on a mp8000 when duplex scanning a double sided image the first side scans fine but the second side comes out like this mp8000.pdf any help will do thanks
Mp8000 duplex scanning issue
Re: Mp8000 duplex scanning issue
if the problem hapens again you have a bad DIMM in the controler -
The bar codes look like a memory DIMM issue or maybe a bad CIS.
The light CQ looks like the large white roller springs are stuck. I've gotten similar light CQ after cleaning label gum off of the white roller, but only on one side of the page.Comment
A quick test for the RAM would be to test with different resolutions.
If the problem changes (worsens at higher DPI), that is a near certain indicator of funky memory.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
I'm pretty sure it will be the CIS, it looks almost exactly like an issue I had a few years back. If it was a memory problem I would expect the image/text itself to be wonky, but it looks complete.Comment
