DX 3240 ERROR 02
  • LEEDSOCE
    • Feb 2015
    • 3
    DX 3240 ERROR 02
    Hi
    Having a problem with a DX 3240 Duplicator generating an 02 code.
    Have replaced the 2 height sensors also the loom assy.
    The paper table travels up to the feed roller but the other
    end of the paper tables travels a bit further as a result the table is
    at an angle.. Any information regarding this problem would be appreciated.
    Thanks in advance
  • Bantams
    • Jun 2012
    • 603
    Re: DX 3240 ERROR 02
    remove the tray lift motor and try lift the tray by hand sounds like something blocking it from lifting evenly either at the front or the rear remove the front and rear covers and you should be able to see whats blocking it .
      • 37365
      There are a couple of places both in the front and the back where if you put the wrong length screw in, it will stick out through the side frame far enough for the paper table to hit. Voice of experience.
