SPC430DN SC452
  • sandmanmac
    replied
    Re: SPC430DN SC452
    I must admit, I overlooked your inclusion of SC400.
    You've only cleaned the ID sensor, but it may need replacement, otherwise likely the BCU.
  • GeorgeBest
    replied
    Originally posted by sandmanmac
    Also? So at some point you weren't aware then...because it was never going to be a belt issue.
    So then, it's either the contact sensor or the motor.
  • sandmanmac
    replied
    Re: SPC430DN SC452
    Originally posted by GeorgeBest
    I understand . .
    swapped the roller also.
  • GeorgeBest
    replied
    Re: SPC430DN SC452
    I understand . .
    Let's be clear.....You understand that this is a transfer roller error, and not a transfer belt error ??
  • sandmanmac
    replied
    Re: SPC430DN SC452
    swapped the entire transfer unit . . .
  • GeorgeBest
    started a topic SPC430DN SC452
    SPC430DN SC452
    Error SC452 is returning on this machine. (Also SC400 sometimes)
    Checked sensors, cleaned the ID sensors, swapped the entire transfer unit . . .
    Sometimes the machine works fine, but for only a small period.
    some one a clue here ?
    Just a couple of machines in the field.
    Thanks in advance
