Twain Driver for Aficio 551
  • sognen
    • Jul 2014
    • 24
    Does anyone knows where I can find a twain driver for Ricoh Aficio 551?
  • rthonpm
    • Aug 2007
    • 2849
    Re: Twain Driver for Aficio 551
    What operating system are you looking for? I haven't seen one of those in a very long time, but you likely won't find a 64-bit driver if that's what you need. If it's on the network though Windows may be able to just use its own built in scan utility to work with it. That said that model is pretty much a throwback to the Windows NT era at this point so your options are going to be very limited.
    • sognen
      • Jul 2014
      • 24
      Well at this point I'm working on windows 7 x32 bit but if there is a windws xp driver will be ok.Correct me if I am wrong, I was said that the machine can work just with twain because i scan router is not bit in the macine.
      • impetus73
        • Mar 2012
        • 75
        551 is not verry supported anymore.
        IMPORTANT NOTICE: Driver and Utility Support for Windows XP discontinued
        We have discontinued the support for Windows XP since 9th April, 2015.
        As a result, all Windows XP drivers have been removed from our download page.
        Background: Microsoft has discontinued its support of Windows XP.
        The other OS'es only have mini drivers for this model, no twain.
        Why not use scan to email?
        • sognen
          • Jul 2014
          • 24
          I haven't set up any scan to e-mail on this device. Can I scan to e-mail on yahoo/hotmail/gmail on this device ?
          • impetus73
            • Mar 2012
            • 75
            You can scan to any email address you want in the whole world.
            To get scan to email to work, make sure the firmware is the latest, then you need the following info:
            Customers SMTP server, (Usually the mailserver of the Internet Service Provider)
            You need to make sure the IP address is valid, and the subnetmask and gateway, and also the DNS server. (You can use Google's DNS servers: 8.8.8.8 or 8.8.4.4)
            You also need a valid administrators email address (Senders email), set up at the machine, for example: scanner@customersISP.com
            if all this is ok, then you should be able to scan to email, unless something is blocked, or they use other ports for SMTP.
            You can not assume that the settings that work with one customer, works with another, you have to make sure all the info above is right for THAT customer.
              • 37382
              If this model had scanning of any type it would have been using Scan Router. It is far too old for scan to email.
              • trc
                • Jan 2007
                • 95
                • impetus73
                  • Mar 2012
                  • 75
                  Odd, but true... how quickly one forget :-D
                    • 37382
                    Originally posted by trc
                    Only Print option!!!
                    And sometime getting that to work properly was a pain.
