MPC2050 no hard drive?
  • copyaction
    • Oct 2007
    • 985
    Found and mpc2050 at my wholesaler and it looks as if there is no hdd.
    the fax won't load shows document server unavailable and scan says cannot store.
    so I'm thinking they pulled the hard drive before returning it.
    one question where is the hdd on this model?
  • LNorris
    • Sep 2008
    • 645
    Re: MPC2050 no hard drive?
    should be in the controller box
    • copyaction
      • Oct 2007
      • 985
      thanks, found it and they took out the mounting bracket and connectors too.
      • Iowatech
        Not a service manager
        • 3930
        Unfortunately, you are likely to encounter this problem frequently.
        Thanks mostly to the initial users doing things with the machines that they were not designed to do, the hard drives on many machines are being removed before they show up at the wholesalers because of security concerns.
        Sorry.
        • copyaction
          • Oct 2007
          • 985
          Sorry.
          I know what you mean, it would just be nice if they could just remove the hard drive and leave the mounting bracket and connectors.
          • logrady2331
            • Feb 2011
            • 301
            Be glad it isn't an MP6001, 7001, 8001 or 9001. If the bracket is missing all you can do is order the complete assembly (Ricoh won't sell just the brackets). That little jewel is 500.00.
            • logrady2331
              • Feb 2011
              • 301
              Ricoh and Sharp Parts 50 to 80% Off Harvested Parts for the bracket/hdd.
              • copyaction
                • Oct 2007
                • 985
                thanks, it arrived yesterday and thats where I got it.
